Guest
Posts: n/a
Hi,
Would you happen to know what are the torque values for the two bolts that hold the vacuum pump to engine block on an R56 Cooper S? Also, is it necessary to use a sealant like RTV on the mating surfaces? __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Vacuum Pump Replacement |
Don't use RTV unless called for, most gaskets do not require it.
I don’t have the torque info. I would grab a repair manual. It will have the procedure, special tools and torque specs. Give our parts specialists a call at 1-888-280-7799. - Nick |
