Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Extra connector after engine rebuild
I had to replace the pistons in a 2007 R56. Done with the job with the exception that I have an extra connector and I can't figure out where it should go. I included a few photos. The wire is located under the intake manifold in the area below the starter. There is a joint under there with a black connector on the left, and a brown one on the right. I can't figure out where the other end of the brown should attach to. Any help is greatly appreciated.
Ed
Old 03-09-2016, 09:14 AM
Administrator
Luccia at Pelican Parts's Avatar
It's really hard to tell from your images. Sometimes the starter has more than one small wire on it, but I can't tell from your pictures. I'd probably recommend to try and start it and see if a fault sets or something doesn't work. Then, you will have an idea as to what they might be too.
Old 03-10-2016, 01:43 PM
