Guest
Posts: n/a
I replaced my battery with gel type. My idle is high now 1500rpms when warm. Is this a battery registration issue? 2004 Cooler S R53
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Battery Replacement and Battery Tender Installation |
Unlikely. Your vehicle does not require registration. The high idle is probably a coincidence. Check for vacuum leaks and fault codes.
- Nick |
