Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
speedman's Avatar
key fob comfort question
I just bought a 2005 mini cooper S and I would like to roll the windows down and open up the sunroof with the key fob. I hold the unlock button down and the doors unlock but no luck with the rest. The manual states this can be programmed
Rick T
Old 03-19-2016, 07:43 PM
Administrator
Luccia at Pelican Parts's Avatar
For comfort opening - Did you press the unlock button to unlock all the doors first and then press it again and hold it down for about 5 seconds? I believe you have to unlock with the first click and then the 2nd one you hold it down and they should roll down. Let me know if this doesn't work. If it doesn't, the programming setting might not be on and you'll have to get it programmed/do a sequence to activate it.
Old 03-23-2016, 01:41 PM
