Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Randall (guest)
Guest
Posts: n/a
Hi Nick thank you for the time and effort with the technical articles.
I'd like to point out that there could be DEBRIS AROUND THE INJECTORS. I saw the debris around valve cover but not under the injector/fuel rail assembly.For some reason my 2005 Mini Cooper S R53 had some small sand particles and/or really small rocks mixed with oily powdery grit. Guess it came through the intercooler. I'm the second owner and only has 55k miles. Ended getting some on the valves and am so scared it will do major damage to my engine. From your experience what do you think?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - R53 Water Pump Replacement
Old 03-23-2016, 10:59 AM
Nick at Pelican Parts's Avatar
I can't see that large of debris getting past the air filter. Unless it wasn't seated correctly. If you get it out, it may be ok. Hard to say if it did any damage.
- Nick
