Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Moniga (guest)
Guest
Posts: n/a
I have a 2006 Mini Cooper that won't shift into first gear but will for the other 4 5 speed manual trans and shifts into reverse. Any ideas what might be wrong before I take it in?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change
Old 03-23-2016, 11:02 AM
Nick at Pelican Parts's Avatar
The cables may be faulty. Check the movement at the trans, see if the shift linkage moves along with the shifter.
- Nick
