Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Davigun92 (guest)
Guest
Posts: n/a
I installed the new mechanism, however, is slower to raise the window relative to the other window. What could be the reason? I oiled somewhere? Can you tell me what is the piece that I highlighted in photos? Thank you :
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 03-25-2016, 06:26 AM
Nick at Pelican Parts's Avatar
Alignment of the regulator may be off. Try adjusting the regulator and glass alignment with the body.
- Nick
What do you mean for "alignment of the regulator"? (I'm sorry I write from Italy)
Thanks for the answer
Old 03-25-2016, 06:53 AM
Administrator
Luccia at Pelican Parts's Avatar
I believe he's talking about pretension adjustment and position adjustment. After installing a new regulator you need to do these 2 adjustments. Did you follow the instructions on these adjustments from Figure 38 in the article? May need to try those steps again to insure the aligment of everything is not off. Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 03-25-2016, 12:54 PM
I followed both the passages, but when I pull the window up with the suckers I don't manage to reach the screws which ensure the glass, because there is not enough room.
Old 03-25-2016, 02:46 PM
