Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Cobraman (guest)
Guest
Posts: n/a
I have a Mini Cooper s roadster. I have just replaced the water pump and I am ready to fill the cooling system. When replacing the water pump I removed the large hose from the inter cooler that goes up and across the front of the motor right side. Is the intercollegiate a separate system or is it a part of the main cooling system? I want to make sure that it is not left empty causing problems in the future.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Draining Filling Cooling System
Old 04-01-2016, 12:50 PM
Nick at Pelican Parts's Avatar
The intercooler does not hold engine coolant. It is for air.
- Nick
