Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Administrator
Luccia at Pelican Parts's Avatar
MINI Driving Lights Retrofit Kits! LED and Non LED Options!
Want to add those cool rally lights that you see on the grilles?
You can get them straight from the factory! You can either get the normal DRL's or the LED options below:
Click Here - DRL retrofit kit in black
Click Here - DRL retrofit kit in chrome
Click Here - LED DRL retrofit kit in black
Click Here - LED DRL retrofit kit in chrome
You'll also need the correct corresponding items below that match your MINI's interior. I can help you with this if you're unsure these are the right ones.
Interior trim piece with button for lights HERE.
Grille and bracket options:
Through 7/11 Cooper S/JCW HERE
7/11 through 7/14 Cooper S/JCW HERE
Cooper Base without chrome line through 7/14 - HERE
Cooper Base with chrome line through 7/14 - HERE
7/14+ Cooper S HERE
Old 04-05-2016, 01:06 PM
Administrator
Also, the kits come with caps, but if you need them separately the black caps are HERE and white caps are HERE. These are the caps that cover the lights to protect them when not in use.
If you need new glass for your lights, if they get damaged, you can purchase those HERE.
Old 04-05-2016, 01:11 PM
