Hi, after replacing the thermostat housing on my R55 08 mini, I kept getting a coolant open circuit code. I could not find any info on locations of sensors anywhere...even my shop manual cd. Finding your sight was fantastic. Excellent descriptions, photos and info on sensors which I am familiar with there operation, just not the locations on this car as I am just starting to work on it..You guys are the best....I cant say enough but I WILL BE BUYING FROM YOU FOR NOW ON....the issue was 2 sensor connectors were switched.....all good now
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Coolant Temperature and Oil Pressure Sensor Replacement |
Thanks for the feedback. Glad we could help.
- Nick |
Yes, always make sure things are properly connected otherwise you can get a coolant system related fault code. I've seen a lot of CTS faults because of loose or connectors being plugged into the incorrect location. Glad our article was useful to you!
