Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
nitsua (guest)
Guest
Posts: n/a
Hi, after replacing the thermostat housing on my R55 08 mini, I kept getting a coolant open circuit code. I could not find any info on locations of sensors anywhere...even my shop manual cd. Finding your sight was fantastic. Excellent descriptions, photos and info on sensors which I am familiar with there operation, just not the locations on this car as I am just starting to work on it..You guys are the best....I cant say enough but I WILL BE BUYING FROM YOU FOR NOW ON....the issue was 2 sensor connectors were switched.....all good now
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Coolant Temperature and Oil Pressure Sensor Replacement
Old 04-07-2016, 08:49 AM
Nick at Pelican Parts's Avatar
Thanks for the feedback. Glad we could help.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Yes, always make sure things are properly connected otherwise you can get a coolant system related fault code. I've seen a lot of CTS faults because of loose or connectors being plugged into the incorrect location. Glad our article was useful to you!
Old 04-07-2016, 12:52 PM
