Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
doug (guest)
Guest
Posts: n/a
This is a little off topic. If you were going to install a weld bung for an oil temperature sender, where would you install the bung?
I do not want it on the bottom of the pan. I also feel like it should not be next to the exhaust.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Pan Gasket Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-07-2016, 07:07 AM
Nick at Pelican Parts's Avatar
It would have to be near the cylinder head, where temps are warmest. So I am not sure how you could do that.
- Nick
