Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Pesterkelley (guest)
Guest
Posts: n/a
Question, I have the 2005 3 spoke steering wheel and I was told that if I buy the 2009 steering wheel and air bag that they fit and will work...Any one know if this is true... as I have a 2009 air bag now and it wont fit the 2005 steering wheel but the guy who sold it says that if I change out the wheel itself it will work..my steering wheel is pretty worn
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Changing Airbag and Steering Wheel (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-13-2016, 02:02 PM
Nick at Pelican Parts's Avatar
I have no info on that swap. Big difference in vehicle there, so I would assume not going to work.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
From what I have seen the R56 wheels should fit the R53's, but as to regards to how I am unsure. Might have to do a bit of research on that.
If your wheel is worn, why not upgrade to a MOMO steering wheel (although you wont have airbag capabilities). Can check them out here - Steering Wheels and Hub Adapters - Pelican Parts
I'll see what I can find out on the R53 and R56 wheel swap.
Old 05-13-2016, 03:46 PM
