Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brompty (guest)
Guest
Posts: n/a
I followed all of your excellent instructions, but missed this small paragraph:
'To drain any remaining coolant from the system R50/R53, from underneath the car, there is a 14mm drain plug green arrow located at the rear face base of the cylinder block adjacent to the starter motor underneath the exhaust manifold heat shield if looking down at the engine.
Can you include photographs for this, please? Everything is covered except this crucial bit which will allow me to get the remaining 3 litres out of the engine
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Coolant Change (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-20-2016, 06:54 AM
Nick at Pelican Parts's Avatar
I don't have photos to share. It would be in a repair manual. Give our parts specialists a call at 1-888-280-7799. They can get you the Bentley manual.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
I'll have someone review and update that particular section in the article. Thank you for pointing this out.
Bentley Manual here if needed: Mini Cooper & Cooper S (R50/R52/R53) - Books & Technical Documentation - Page 1
Old 05-20-2016, 11:23 AM
