Guest
Posts: n/a
I have a 2005 MINI Cooper S Cabrio and recently changed the upper and lower engine mounts to get rid of a knocking noise while braking. Noise went away for a couple of months but now I have a similar knocking noise when backing out of my driveway or when slowing down to a stop. Also happens sometime while accelerating and turning at the same time. Could this be related to worn out control arm bushings?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Control Arm Bushing and Ball Joint Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
it could be. Or worn sway bar end links.
- Nick |
Administrator
Can you determine what area the noise is coming from? Front/rear? Check all bushings. Control arm, ball joints, sway bar links, sway bar mount bushings, etc.
PelicanParts.com - 2005 Mini Cooper S Convertible - Suspension & Steering You can replace what ever may be warn with Genuine/OEM or you could upgrade to Powerflex for prolonged tire life, performance gain, and they're more cost effective. 2005 Mini Cooper S Convertible - Suspension Upgrades & Performance - Page 2 Let us know what you find out. |
