Guest
Posts: n/a
Hi there,i wonder if you can help. I have bad issues in changing the fuel pump and the fuel filter assembly. It started when my fuel gauge were faulty and gave me false information. I removed the fuel filter assembly and the plastic where the level sensor was mounted-in was broken. Dunno how it could broke on the tank... I replaced it, and next was the fuel pump, the small part when you plug the pipe was broken as you see on the photo. I replaced it and now it's broken again. I diagnosed my car with the tool i have, and it give my the folowing "code P27B2 fuel tank vent min". Do you know how could i fix it?.
Mini cooper S R56 2008/50 000km Kind regards ![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
It looks like an impact on the fuel pump. There are marks showing this. I would replace it with a new fuel pump module. Also confirm it is not binding when installing and doesn't have excessive stress on the lines.
- Nick |
