Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Goober (guest)
Guest
Posts: n/a
I just recently replaced my thermostat housing and associated water pipe, but like a goober I didn't mark the sensor connectors so that I could make certain they go back where they should. Is there a way to tell the oil pressure connector from the water temp one?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 06-10-2016, 04:55 PM
Nick at Pelican Parts's Avatar
Oil pressure is one wire. coolant is two wires.
- Nick
