-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Control Arm Bushing and ball joint Replacement (http://forums.pelicanparts.com/mini-discussion-forum/918303-question-control-arm-bushing-ball-joint-replacement.html)
Bing (guest) 06-15-2016 01:36 PM
Do you need to have the steering aligned after replacing the lower control arm bushing?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Control Arm Bushing and Ball Joint Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-15-2016 01:36 PM
Not necessarily. But it is a good idea to do so. when done, if the vehicle drives straight and the steering wheel angle hasn't changed, you should be OK.
- Nick
