Guest
Posts: n/a
Do you need to have the steering aligned after replacing the lower control arm bushing?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Control Arm Bushing and Ball Joint Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Not necessarily. But it is a good idea to do so. when done, if the vehicle drives straight and the steering wheel angle hasn't changed, you should be OK.
- Nick |
