-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/918869-question-automatic-transmission-fluid-change.html)
Delsol (guest) 06-20-2016 10:25 AM
Have a 2003 mini r50 automatic, want to change transmission fluids ND filter like to know what's needed and the procedure for it?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-20-2016 10:25 AM
You should have a CVT trans. That will require CVT fluid and an adaptation when done, using a MINI scan tool.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
