Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Delsol (guest)
Guest
Posts: n/a
Have a 2003 mini r50 automatic, want to change transmission fluids ND filter like to know what's needed and the procedure for it?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article
Old 06-20-2016, 10:25 AM
Nick at Pelican Parts's Avatar
You should have a CVT trans. That will require CVT fluid and an adaptation when done, using a MINI scan tool.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
