Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
alan (guest)
Guest
Posts: n/a
I hesitate to just pull the trim panel after removing the two torx bolts which were quite easy. this panel is VERY firmly attached.
Special tool needed to avoid damage to panel? Info to obtain if needed?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Rear Wiper Arm and Motor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 07-13-2016, 05:54 AM
Nick at Pelican Parts's Avatar
Any plastic trim panel tool should do it.
- Nick
