Spark Plug for model 2007
What was the original SP on the Mini Cooper Hatchback R56 Model with N12 Engine?
I want to change them and make sure the replacement is compatible. Using some site, the plugs listed below are deemed as good replacement: Beru 12ZR6SP03 Beru Z233 Bosch ZQR8SI302 NGK IOLZR6SPO3 Pelican lists "Beru 12 ZR-6 SP2, Bosch ZQR-8-SI-302" for 3 Plugs from $11-$17. 2007 Mini Cooper Base Hatchback - Ignition Tune-Up - Page 1 Thanks |
Well, you can see that the first and third plugs on your list are the ones that Pelican sells...
--DD |
But what is the one that came with the car? |
Spark plug info for the R56 below:
Got it, thanks
| All times are GMT -8. The time now is 09:07 AM. |
