Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
83 911 Production Cab #10
JJ 911SC's Avatar
Spark Plug for model 2007
What was the original SP on the Mini Cooper Hatchback R56 Model with N12 Engine?
I want to change them and make sure the replacement is compatible.
Using some site, the plugs listed below are deemed as good replacement:
Beru 12ZR6SP03
Beru Z233
Bosch ZQR8SI302
NGK IOLZR6SPO3
Pelican lists "Beru 12 ZR-6 SP2, Bosch ZQR-8-SI-302" for 3 Plugs from $11-$17. 2007 Mini Cooper Base Hatchback - Ignition Tune-Up - Page 1
Who Will Live... Will See
Old 07-29-2016, 12:09 PM
914 Geek
Well, you can see that the first and third plugs on your list are the ones that Pelican sells...
--DD
Old 07-29-2016, 02:43 PM
JJ 911SC's Avatar
--DD
I can see that the 3rd one is, as for the first one is "...SP03" the same as "...SP2"?
But what is the one that came with the car?
Old 07-29-2016, 03:50 PM
Administrator
Luccia at Pelican Parts's Avatar
Spark plug info for the R56 below:
The second generation R55, R56, R57 petrol models are fitted from the factory with the BERU: 12ZR6SP03 with the EXCEPTION of the Cooper S these are fitted with NGK: PLZBR7A-G, and the JCW are fitted with the NGK: ILZKBR7A-8G
R56: One/Cooper: BERU: 12ZR6SP03 tightening torque: 20nm (14.5 lbs/ft) thread diameter/pitch M12 x 1.25 socket size 14mm, electrode gap 1.0mm, heat range 6
Cooper S: NGK: PLZBR7A-G and JCW: NGK: ILZKBR7A-8G tightening torque: 15-20nm (10.8-14.5 lbs/ft) thread diameter/pitch M12 x 1.25 socket size 14mm, electrode gap: pre set, heat range 7
All spark plugs listed in our catalog for the R56 are correct. Some equipment (part #'s) do change and update over the years.
Old 09-13-2016, 11:40 AM
JJ 911SC's Avatar
Got it, thanks
Old 09-13-2016, 12:26 PM
