Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
pttrfan1 (guest)
Guest
Posts: n/a
Hi, hope you can help. Trying to change fuel pressure sensor on 2010 mini cooper s, but can't seem to find a listing for a part number. Anyway you can help with this? Thank you in advance.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 08-05-2016, 09:16 AM
Nick at Pelican Parts's Avatar
See this article:
http://www.pelicanparts.com/techarticles/MINI_R56/92-FUEL-Fuel_Rail_Pressure_Sensor_Replacement/92-FUEL-Fuel_Rail_Pressure_Sensor_Replacement.htm
I’m not the best with part numbers.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
