Do you need to reset the "brake pad replacement" light and if so, how?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Front Brake Pad Replacement (R56 2007-2013) | Pelican Parts DIY Maintenance Article |
No, the new sensor will reset it. See here for reset info for CBS data.
http://www.pelicanparts.com/techarticles/MINI_R56/21-BASICS-Condition_Based_Service_Explained/21-BASICS-Condition_Based_Service_Explained.htm ] http://www.pelicanparts.com/techarticles/MINI_R56/21-BASICS-Condition_Based_Service_Explained/21-BASICS-Condition_Based_Service_Explained.htm [/url] - Nick |
In some cases, even replacing the sensor will not reset the light. I had to use the button on the turn signal stalk and the button on the tach to reset the light on my 2012 Cooper when I replaced the rear brakes and sensor.
| All times are GMT -8. The time now is 08:49 PM. |
