Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
glassesgrl64 (guest)
Guest
Posts: n/a
How critical is it to replace a vanos exhaust camshaft gear if it is throwing a 2845 code? My car still seems to run fine, it's just a little sluggish. I have only had it a few months but I am getting used to the way it drives. I was quoted $1,00 for this repair, so I am not sure what to do.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-26-2016, 07:15 AM
Nick at Pelican Parts's Avatar
if it fails, the vehicle can have starting issues or low power.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
It's always important to fix a failing part before it causes other issues that will cause your $1,000 bill to go up. If you're DIY handy that will also help keep the costs down. You can also find a local MINI indy shop that specializes in MINI's specifically instead of taking it to a general automotive repair shop or the dealership.
DIY - MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Part - 2007 Mini Cooper Base Hatchback - Cylinder Head & Valvetrain - Page 3
Old 08-31-2016, 08:31 AM
