Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Simonrw (guest)
Guest
Posts: n/a
Hi. We have a 2009 cooper S which has an oil leak. Not too seriuos. It also developed a cooling problem which, using your excellant articles, we diagnosed as being the water pump. We removed the water pump and the vehicle has been standing for 2 days. I now notice a large pool of oil under the water pump area. The oil is dark and does not appear to have water mixed with it. Any suggestions?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Leak Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-12-2016, 06:55 AM
Nick at Pelican Parts's Avatar
Could be a crank seal leak. I would look for signs of the leak on the engine. Look for a clean we spot, that will likely be the source.
- Nick
