Replaced alternator , belt tight but battery
Light on and show below 13v @ 2000rpm Checked connections , ok but Still battery light, missing somethi ng? __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Could be low current or not the voltage the DME is requesting.
- Nick |
So What is the Voltage the computer wants to see. Removed the alternator to test, but if
tests ok could the battery be marginal and cause the less than desirable current or is this a fault/short somewhere else. |
Removed new alternator bench tested 8v ..
.. chuncked that now have a. New new one Any issue that might have fried stock one and Replacement alt so I don't install third and screw It up . Original only put out 11v , replacement 8v is second one a bad build and not a elec. Issue Don't see any blatently bad wiring . Any ideas? |
Hello HawnMini - try posting your question to the tech article comments section, like you did with the first one. Nick should respond to it that way.
MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article Scroll to the bottom where it says "write a comment." |
| All times are GMT -8. The time now is 09:07 PM. |
