Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
pj (guest)
Guest
Posts: n/a
Replaced alternator , belt tight but battery
Light on and show below 13v @ 2000rpm
Checked connections , ok but
Still battery light, missing somethi
ng?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 08-26-2016, 07:14 AM
Nick at Pelican Parts's Avatar
Could be low current or not the voltage the DME is requesting.
- Nick
So What is the Voltage the computer wants to see. Removed the alternator to test, but if
tests ok could the battery be marginal and cause the less than desirable current or is this
a fault/short somewhere else.
Old 09-25-2016, 03:58 AM
Removed new alternator bench tested 8v ..
.. chuncked that now have a. New new one
Any issue that might have fried stock one and
Replacement alt so I don't install third and screw
It up . Original only put out 11v , replacement 8v
is second one a bad build and not a elec. Issue
Don't see any blatently bad wiring . Any ideas?
Old 09-27-2016, 11:09 AM
Administrator
Luccia at Pelican Parts's Avatar
Hello HawnMini - try posting your question to the tech article comments section, like you did with the first one. Nick should respond to it that way.
Scroll to the bottom where it says "write a comment."
Old 09-29-2016, 09:32 AM
