Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
sparkyj (guest)
Guest
Posts: n/a
What is the easiest and best way to remove only the top plastic reservoir without disrupting the master? And can this carefully be done without introducing air into the system lines?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Master Cylinder Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-15-2016, 06:11 AM
Nick at Pelican Parts's Avatar
Remove the fluid using a pump. Then pop it off then on. As long as you don't open a line once removed, no air should enter the system. Install the new reservoir, then allow it to vent as fluid is added, the air should escape.
- Nick
