Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Miniwoo (guest)
Guest
Posts: n/a
Lost all brakes on 2002 Cooper S - all brake system lights came on. Replaced badly corroded steel lines - front to back, both sides. Bled brakes, all working great but all warning lights still on - how do I turn these off.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Stainless Steel Brake Line Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-15-2016, 06:33 AM
Nick at Pelican Parts's Avatar
Clear the faults using a MINI scan tool.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
AutoEnginuity is the tool I'd suggest as it has a wide variety of what it can do as far as diagnostics. You can read more about it here: 2002 Mini Cooper S Hatchback - Tools - Page 9.
You'll want to purchase the expansion for BMW/MINI as well. Be sure to check out the items below "Links" at the link above to see comparisons and a tech article showing you what it can do. Let me know if you have any questions.
Old 09-15-2016, 09:02 AM
