Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
TC (guest)
Guest
Posts: n/a
Have a 2013 R56 Cooper S, 6 speed Manual. Where do I find Which transmission I have, the GS6-55 BG or the 58 BG. Where is it stamped on the trans, or can it be found through the VIN? I would like to go to Red Line in my Mini if possibleworked great for my E46 manual trans. Preventative maintenance is worth every penny.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-22-2016, 05:06 PM
Nick at Pelican Parts's Avatar
VIn may show what it had. For an instant response, give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Your '13 R56 S should have the GS6-53 BG transmission. According to the Red Line application guide, I do not believe Red Line makes a fluid for your transmission. However, you may be able to give them a call to see if there is something they may offer that will work.
Red Line - Red Line Synthetic Oil Products - PelicanParts.com
Genuine Fluid - 2013 Mini Cooper S Hatchback - Transmission - Page 1 (the Red Line Oil listed at that link is the one you'll want to check with them about).
Old 09-28-2016, 10:15 AM
