-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Alternator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/930794-question-turbocharged-engine-alternator-replacement.html)
Mannt (guest) 10-01-2016 05:22 PM
Doing the R56 Turbo alternator and on the last step but that E10 Torx is blocked by the rigid ac line. I dont see any instructions on moving the line and it isnt obvious just by looking at it. How disappointing after 7 hours. Help!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Alternator Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-01-2016 05:22 PM
Place the radiator support in service mode. See our tech article on radiator support service mode. Remove the engine-cooling fan. See our tech article on engine cooling fan replacing.
This will allow access, if needed use an E10 wrench, not a socket.
- Nick
Luccia at Pelican Parts 10-03-2016 09:17 AM
Service mode tech article: MINI Cooper R56 Radiator Support Service Position (2007-2011) | Pelican Parts DIY Maintenance Article
Engine cooling fan tech article: MINI Cooper R56 Cooling Fan Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
