Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mannt (guest)
Guest
Posts: n/a
Doing the R56 Turbo alternator and on the last step but that E10 Torx is blocked by the rigid ac line. I dont see any instructions on moving the line and it isnt obvious just by looking at it. How disappointing after 7 hours. Help!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Alternator Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-01-2016, 05:22 PM
Nick at Pelican Parts's Avatar
Place the radiator support in service mode. See our tech article on radiator support service mode. Remove the engine-cooling fan. See our tech article on engine cooling fan replacing.
This will allow access, if needed use an E10 wrench, not a socket.
- Nick
