Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mr rj (guest)
Guest
Posts: n/a
Hi,i have 2003 r50 mini cooper,the problem is speedometer
Appear EP at gear indicator,car not moving nicely like used third gear without changing,can u advise me,its about battery or other else part problems,tq rj
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Battery Replacement and Battery Tender Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 08:39 AM
Nick at Pelican Parts's Avatar
If battery voltage is low, it could cause an issue. check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
