Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rick (guest)
Guest
Posts: n/a
Need help with what cooling hose this is
this part is leaking on my 07 mini and I need HELP,what is this part called and were can i get it ,and the hose, no one lists this part in any place i have looked. some show the part but no part number
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Cooling System Leak Test (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 08:48 AM
Nick at Pelican Parts's Avatar
You need the hose. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Hello Rick - is your '07 MINI a Cooper or Cooper S? Can you give me the last 7 digits of your vin by chance?
The coolant hose that mounts to the bottom of the expansion tank and runs towards the thermostat housing is here - Coolant Hose 17122754573 - Genuine MINI - BMW - 17-12-2-754-573 | Pelican Parts. Let me know if you need a different part.
Old 10-10-2016, 09:43 AM
