DIY on thermostat replacement for R56 JCW?
Do you have a "how to" on replacing the thermostat on an 09 JCW?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Also, if you need a thermostat we have them here: 2009 Mini Cooper JCW Hatchback - Thermostats.
If you decide you want to do a cooling system overhaul and do the water pump at the same time, we have some pretty awesome kits here: 2009 Mini Cooper JCW Hatchback - Water Pump Super Kits for MINI R55/R56/R57. |
| All times are GMT -8. The time now is 10:23 PM. |
