Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Oz (guest)
Guest
Posts: n/a
DIY on thermostat replacement for R56 JCW?
Do you have a "how to" on replacing the thermostat on an 09 JCW?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-20-2016, 05:00 AM
Nick at Pelican Parts's Avatar
See this article:
http://www.pelicanparts.com/techarticles/MINI_R56/89-WATER-Turbocharged_Engine_Thermostat_Replacement/89-WATER-Turbocharged_Engine_Thermostat_Replacement.htm
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Also, if you need a thermostat we have them here: 2009 Mini Cooper JCW Hatchback - Thermostats.
If you decide you want to do a cooling system overhaul and do the water pump at the same time, we have some pretty awesome kits here: 2009 Mini Cooper JCW Hatchback - Water Pump Super Kits for MINI R55/R56/R57.
Old 10-21-2016, 09:59 AM
