Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
boomtrike (guest)
Guest
Posts: n/a
hi.can i just lower the fronmt subframe just enough to fit a new front wishbone rear bush if so how easy is it
thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Subframe Removal (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 11-04-2016, 11:15 AM
Nick at Pelican Parts's Avatar
It is worth a try. You may have enough space to work. Just be sure you don't put stress on hose or wiring when lowering it.
- Nick
