Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
AJK (guest)
Guest
Posts: n/a
I have a 2009 Mini Cooper S. It seems like I'm adding 1/2 a liter to a full liter of oil at every third fill up. I don't see black smoke coming from the car but there is a soot build up on the tail pipes.
I notice an increased oil consumption when I run the car in "Sport Mode." I'm wondering if this has to do with a bad seal on the Turbo Charger?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Consumption Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 11-04-2016, 11:19 AM
Nick at Pelican Parts's Avatar
Could be, or a faulty oil separator.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
How many miles are on your R56? MINI says it's normal to burn a quart of oil about every 1000-1500 miles. Now, this being said as "normal" has been discussed to the death. Personally, I don't believe an engine should consume oil at this rate, but many different manufactures say the same thing as MINI. You can check for oil leaks to be sure that you're not losing oil that way: MINI Cooper R56 Oil Leak Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article.
Old 11-08-2016, 10:05 AM
