Guest
Posts: n/a
I just installed Megan coilovers and on figure 2 i did not reuse the triangular washer since it seems the bolt already has a washer head to it. Would this be ok or would i need to reinstall with that triangular washer?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
It should be used. it is there to prevent the shock from coming off if the bushing fails.
- Nick |
