-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Intercooler Replacement (http://forums.pelicanparts.com/mini-discussion-forum/936238-question-intercooler-replacement.html)
Matt (guest) 11-18-2016 01:55 PM
Hello. If you wanted to check your fuel pressure when the intercooler is removed, is it safe to run the engine and if so, for how long?
Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Mini R53 Intercooler Replacement | R53 Cooper (2002-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 11-18-2016 01:55 PM
Do not run the engine with the intercooler off. Set up your tester, run the hose out of the way, then reinstall the intercooler.
- Nick
