Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Matt (guest)
Guest
Posts: n/a
Hello. If you wanted to check your fuel pressure when the intercooler is removed, is it safe to run the engine and if so, for how long?
Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Mini R53 Intercooler Replacement | R53 Cooper (2002-2006) | Pelican Parts DIY Maintenance Article
Old 11-18-2016, 01:55 PM
Nick at Pelican Parts's Avatar
Do not run the engine with the intercooler off. Set up your tester, run the hose out of the way, then reinstall the intercooler.
- Nick
