-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Front Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/939120-question-front-brake-pad-replacement.html)
Bob (guest) 12-13-2016 09:41 AM
Thanks for posting this - good tip about removing the slide bolt. I cleaned them off and wiped on some new lubricant. There must a difference in some of the Mini models as our R56 2010 required a 16mm thin wall wrench. Good thing too as I did not have a 17mm that would fit!
Biggest pain I found was attaching a new wear sensor - had to remove a lot of screws to pull out the wheel well cover!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Front Brake Pad Replacement (R56 2007-2013) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 12-13-2016 09:41 AM
Thanks for the additional info and feedback. We appreciate it.
- Nick
