Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sue (guest)
Guest
Posts: n/a
2006 mini cooper convertible
First Question on Tailgate light:
Does it matter if Rear Backup Lamp 16W is replaced by a 16/18W original bulb only 16W?
Flosser
Bulb; Wedge Base, 16/18W
2nd Question:
What do I need to fasten rear left trim arch to my mini?
How many clips etc?
There are 5 white knobs and 2 holes.
Thank you. Videos are great!
Sue
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Lens and Bulb Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 12-16-2016, 04:01 AM
Nick at Pelican Parts's Avatar
You have to use the same wattage that is originally equipped.
You will need 5 clips. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
It's always good to replace bulbs in pairs as well as it is most likely that the other one is on its way out as well.
The correct replacement bulbs are inexpensive and are a safe option to go with: 2006 Mini Cooper Base Convertible - Lights and Lenses - Page 6.
The 5 white knobs needed for your wheel arch are here: Pelican Parts - Rear wheel arch clip
Clips:
Pelican Parts - MINI Wheel Arch Trim Clip
and
Old 12-22-2016, 10:11 AM
