Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Damo (guest)
Guest
Posts: n/a
Hi if one of the cylinders has 0 compression will this mean the cleaner will enter bore
Many thanks damon
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Carbon Cleaning (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-28-2016, 08:04 AM
Nick at Pelican Parts's Avatar
Means you have a major compression loss. Faulty valve or piston.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
You need to do a leak down test, but you might have some engine issues. What year/model MINI is it?
Old 12-29-2016, 12:49 PM
