-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Oil Cooler Filter Housing Replacing (http://forums.pelicanparts.com/mini-discussion-forum/941210-question-turbocharged-engine-oil-cooler-filter-housing-replacing.html)
gomez auto (guest) 01-03-2017 06:41 AM
11'mini S r56 will a failed oil cooler seal cause a coolant/oil mix?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Oil Cooler and Filter Housing Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 01-03-2017 06:41 AM
Yes, that is possible.
- Nick
Luccia at Pelican Parts 01-03-2017 09:04 AM
Be sure to check it over for any type of pitting as well, which is referenced in Figure 2 of that article.
Coolers and gaskets (at the bottom) are here if needed: 2011 Mini Cooper S Hatchback - Oil Circulation - Page 3
