LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
11'mini S r56 will a failed oil cooler seal cause a coolant/oil mix?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Oil Cooler and Filter Housing Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Yes, that is possible.
- Nick |
Administrator
Be sure to check it over for any type of pitting as well, which is referenced in Figure 2 of that article.
Coolers and gaskets (at the bottom) are here if needed: 2011 Mini Cooper S Hatchback - Oil Circulation - Page 3 |
