Guest
Posts: n/a
Thanks for the instructional.I have an 07 r56 cooper with climate control. One of the climate control servos is in the way of one of the motor screws and I can't get at it. I can't seem to be able to remove the servo, is this likely a dashboard out job?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Blower Motor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Yes, if you can't get to it, that may be the only way to gain access. You can try using a bit and a small wrench to loosen the fastener. But your issue seems more like space restriction.
- Nick |
Guest
Posts: n/a
Thanks for the reply. I took the dash out, metal frame for dash had to come out as well. not so bad taking it apart and got very easy access to everything I needed when I did. Putting it back together takes a bit longer ;. I'm not telling the wife what I've done to her car!
Glad you got it done and thanks for the follow up.
- Nick |
